1 Attachment(s)
Bit of an up date and maby an idea for others with the same problem.
I was getting sick of draining the can by hand and making a mess so i made this set up and have tested it for a few mnts before posting it up on here.
All the bits inc the hose came from Enzed so your local should be able to help.
They only thing you may need to borrow is a nut sert kit, they are pretty expensive.
The rest is just hose, a hose clamp, ball valve, 2 barbed fittings and 2 hose support clamps.
The two holes are all rdy in the chassis rail but one needs opening up a tad to fit the nut sert.
Its about 30 min work once you have the bits and then draining the can is a 10 sec job.
Attachment 43798
good idea with the valve and hoses neat to mate good job
Like it. Nice mod :smiley_thumbs_up:
1 Attachment(s)
Very neat indeed. Well done. Blocking the EGR should take no longer that two stubbies mate. Which pipe did you end up blocking?
The one closest to the front of the engine, i had some pics sent to me and found out that i had been sent the wrong blank plate so hence the confusion.
