Why not get all 4 a make one fit into the factory disconnect unit
Not sure if that will work as the disconnect is shaft, not thread..
The bloke a BTE has made these kits so it extends the travel length of the disconnect, so your sway bar has less resistance for a greater length..
Owner of
Westy's Accessories
Cheers guys........ so for the sake of this weekend I should install 3 of them and while 4wding just disconnect the 4th for the day???? then get the 4th one sorted later?????
Do them all at a later day. The disconnect will need to be extended. You could do the just front for your trip but you can't just extend one link on the rear.
There are people who make something to allow the disconnect to work better while also extending it. Westy mentions it in post #12
Yes but I dont know who he is talking about?? BTE???
Border track engineering
Try superior they do them
Just spoke to a bloke who said they put the normal set up in them and do away with the disconnect????
Jonathan just fit the fronts we'll remove the rear until you sort it out, you wont feel the back as much as the front.
