I just fitted new tigged IC and forgot to plug in boost sensor , so thinking that's doing nothing,
The piece woud make any install of boost very neat, well thought out
Do you have link ? Very interested
This is exactly what mine looks like.
http://www.extremelimitsoffroad.com....atrol-zd30-crd
Can see mine here fitted nicely
Edit. found a second pic
Think he means if only running a boost gauge this is perfect,
but also if Fitting NADS you could TEE into it to pick up the DAWES valve.
Makes sense
Edit The more I look at this product and the price I think it could be made for
the price of the 3mm brass hose barb. I'll give it a shot and see what I come up with.
Cheers for the photos meh. Just curious, how accurate would these be since they're plugged in close to the outlet side of the IC. Isn't the norm to go as close to the inlet as possible ?? I may be wrong.
I teed mine to use with Dawes and boost gauge
works a treat . Just make sure you don't tighten the plastic cover to tightly . may crack the plastic cover ( as the boost sensor will sit higher )
Boost readings seem to be along the lines as others on the site. Never had an issue with it
