Alitis007
When we do the test we have to make sure all retractable seat belts retract, lock and are not damaged in any way, we check the drivers seat is not torn and has any exposed springs for the back rest or has excessive play in the mechanism, we check the front de mister blows hot air to the windscreen, the "T" bar light (PRND21) works when the lights are on, hand break warning light turns on, high beam indicator works and is bright enough to be seen, the cluster back lighting lights up the dials and doesn't have any blown globes, check the horn, electric mirrors work in all directions, steering wheel grip is not damaged or loose, drivers door hand and window work.
Theres a bit in it and everything that we have to inspect is not listed on the certificate but in the inspectors guidelines there is an extensive list that we go thru to make sure the car is safe. Licensed vehicle testers also have to do a structural awareness course aswell, so if we can see that a car has been in an accident and has been repaired incorrectly it will also fail.
