Or try one of those manifold stud removers. I think Trade Tools in Nambour have them
Thats what a vice grip is, You know those plyers with the screw at the back,
made for this job
I'm thinking that the sender unit is probably a little big for just standard vice grips.
I know it might be a little hot. But take the car for a hard run then try and crack it. Failing that I have plenty of tools down here if you want a hand.
Remember guys to read the op. He only broke the wires off it he hasn't broken the fitting that attaches it to the block.
On really tight things, I have always found that trying to tighten a bit first can crack them.
As above, get the engine warm as well, that little bit of expansion could well help.
Finally going to get another chance to have a go at it tonight. Will get the engine warm again, and will try to tighten then crack if possible. If trashing it is neccessary to get it out, so be it - they can't be that expensive to replace...
Thanks to everyone for their helpful suggestions.....
