Glad it was only minor panther . happy motoring once more .
If the rubber boot on the slave cylinder is stuffed, don't just replace the rubber boot, the slave cylinder bore is stuffed
Throw a new slave cylinder in
Its a common ploblem as the boot gets damaged over time and stuff gets in the slave cylinder bore,like grit,dirt ect and scores the bores and the fluid leaks past the slave cylinder piston
That cheap new, throw the old one out,throw a new one in .....
Something else to watch also, with time the master cylinders get stained,and can look full from the outside but can be empty on the inside, good check take the lids of ,frequently and check
