Offset won't FIX scrubbing but it will help. I run -26 offset and still get scrubbing. I can't gat any bigger offset as the wheels already stick a tiny bit past the flares.
Body lift will help reduce tyres catching the wheel arches tho.
I think many have issues,could be wrong tho,as the usey tiny body blocks,like 50mm diameter and theres plenty of movement to cause cracking mounts
My blocks are as big as i can go within the actual body mounts,about 75-80 mm diameter,with a spacer plate inside the cab,not just a small washer
The front and rear blocks are 100 mm diameter and solid steel not alloy,heavy yep,and i also increased the bolt size some what
It all helps with movement or hopefully lack of, movement here and there cracks things
A lot crack when they remove the rubber factory mount.. you need to leave it in to allow flex..
I ran solid 80mm shaft on all 10 points of my lwb gq and went a m12 bolt over the m10.
Over kill for a 1" body lift. Yes... But I like to guarantee longevity.
Pros of a body lift
Cheap, easy
Cons
Still limited articulation, risk body damage, still need to change brake lines, diff breathers of adding to a 2" spring, throws bar work out of whack and anything more than a 1" body lift and stock barwork looks crap imo...
also front fill pannels need to be remade.
Owner of
Westy's Accessories
I beg to differ a little. Lifting the body instead of your entire drive train will keep the COG lower, meaning more stable off road. A suspension lift doesnt always necessarily net you more travel. It helps yes but the biggest thing that stops everyone is diff clearance. I have always pondered with the thought of running a 2" suspension lift with my current 2" body lift and modifying the top shock mounts to allow the fitment of longer shocks, these coupled with some nice flexy coils and 37's would have an awesome setup. I do like my body lift it makes the car easier to work especially if doing a clutch and before I lifted it could fit 35's with no issues on -22 rims with a 2" spring and 2" body lift. The biggest drama I had with this was down travel, I lifted wheels due to shock length. A suspension lift is also a slight compromise as well, your point of max up travel isnt really changed so your back where you were with standard suspension. I hope this makes sense I can make sense of it myself but may not have conveyed it very well.
That's pretty much what I was trying to say. 2" + 2" seems good to me. It must keep c of g lower as the engine and axles are foookin' heavy , as I've just found out lol
Didn't want to shout too loud as new to this malarky ;) but loving it long time xxx
I'm refurbing some axles at the mo and will be modding the shock mounts to get more droop for same shock length (I'm a poor church mouse ) and then use some cheap coil dislocators.
So will you be raising or lowering the front tower top?
And what's the plan for the rear?
Owner of
Westy's Accessories
I'm refurbing the axles now. Shock mounts are work in progress. I'll do some pics in the next day or two to try and show you what I'm thinking ;)
I agree the C of G will be a little better with a BL over a suspension lift but either way your C of G will rise with either and consideration should be given to that effect when driving after the modification.
If you do go a BL then you get a bonus. Lifting the body opened up the top of the shock tower on the front and allows you to unbolt and remove the upper shock tower and install 50mm lift blocks and fit the tower on top of these. Don't try and modify the lowers on the diff, not required if you have a BL.
I'll see if I can find the pic in my build thread and repost it here for you mate.
http://nissanpatrol.com.au/images/St...g?t=1277817144
Sorry about the size of the pic, on my iPad and had to just grab it out of my build thread
You will find the suspension pics on page 3 of my build thread in my sig line mate
Havent been on in a fair few days, im drugged up to the eyeballs at the moment due to a broken wisdom tooth, 4 different box's of meds, its pretty average haha
Anyway, even know i wasnt fond of body lifts at all, i kinda picked up a 2" Susp Lift and a 2" BL for $300 today so after hearing the pros and cons and everyones opinion ive decided i will probably fit the blocks after all.
I get you mate, and thats what ive been thinking about, down travel, is there that much involved to fit longer shocks?
