I would have if I ha the access to a mig but I didn't, I also wanted to test myself out as I hadn't done this before
So you had a half done rivet in ever one of those holes at the same time and just worked them all giving little tugs to each to work the steel out? The benefit is that the holes will be an etch for the bog to hold too. Nice one. I will give that a go on my rear quarter i reckon.
Cheers MR
i have been told to tac weld to the panel and pull but i dont have a welder ;) the rivets will work well i think.
Yeh mud that's how they do it in the states, there's a specific tool I saw on YouTube but this is the same principal, all credits too three dogs for this too
And yeh just worked along and went back over, I probably should have done more though, the more you can do with the rivets heaps less work later on
Well after almost a week of lunch breaks and after work hours it's almost finished and I am quite excited about the results!
The last run of bog before a sand and paint.
http://imageshack.us/a/img138/396/img1069j.jpg
This is the multipurpose heavy duty bog I used, quite impressive.
http://imageshack.us/a/img841/5446/img1064gd.jpg
Neat little orbital that helped more than I could ever thank it for, for $109 who can complain?
http://imageshack.us/a/img832/8128/img1063db.jpg
After 2x Undercoats and 3x Black Gloss coats before I put some clear coat on tomorrow and the day after
http://imageshack.us/a/img850/545/img1085u.jpg
My checkerplate doors, only finished 1 as I was curious whether NP.com reckons I should use silicone behind it or not.. If I don't get some feedback I'll have to post elsewhere :\
http://img600.imageshack.us/img600/8301/img1089sy.jpg
Bump to add some pics to this.
So after seeing this thread I used this technique to sort out rear quarter panel damage. Saw this thread linked today and bumped so I could add some pics. I might do a separate thread too.
So here is the dent
Attachment 43333Attachment 43350Attachment 43351
Here is the tools I gathered
Attachment 43334
Here is the system
Attachment 43335Attachment 43336Attachment 43337Attachment 43338
Out with the vice grips and slide hammer
Attachment 43339Attachment 43340
Patience, reset, red rill,
Attachment 43341Attachment 43342Attachment 43343Attachment 43344Attachment 43345Attachment 43346Attachment 43346Attachment 43347Attachment 43348Attachment 43347Attachment 43349
Worked a treat. I laid fiberglass over the panel then bogged and sanded then painted. Came up a treat. Thanks for the idea.
On a side note! Next trip out I smashed this panel again, it's ok though! I also smashed the other rear quarter and both front quarter panels!!! Happy dayz
Instead of making swiss cheese out your quarters you could get a straight tip for the sliding hammer and tack weld it onto the panel and pop it out. If you tact the sliding hammer to the lowest part of the dint you would only need to pull it out a couple of times!
