For all the hassle just stick with the high lift, i have also seen those ballon jacks that sit under the car and inflate with exhaust gases but not sure how good they are or how safe either!!
Even running 35s you are a total of 2" above a 31 so a piece of 8" x 2" will be enough for a standard jack. Jack goes under the axle and should have no trouble lifting your car off the ground.
If offroad then I have been known to dig a hole once the flat tyre is off so I can fit the bigger hard tyre if the car is not high enough.
I also carry a exhaust jack and I am a big fan! Great if you are I a bog when your changing tyres, great for soft ground and great for sand.
I hate Hi Lift Jacks! Bloody dangerous and renowned for being faulty if not used often and in the hands of an inexperienced operator. Very common for a HiLift to jack up the car but then fail to lower. Time to loose a finger.
Hey George.
Mate bar news for you mate. Where are to going to jack off your car with a Hilift?? If you wanted to change a front tyre you could not? The back wheel would require you to jack off your tow ad only and you'd have to lift both rear wheels off the ground mate! Not so good.
I am on the iPhone but there are some great threads on the use of exhaust jacks here, worth a search for sure.
Cheers MR
Thats a good point Darren BUT i don't need at high lift ATM lol but if i was on uneven ground i would improvise for the front like use the bottle jack to life the diff housing as high as i could then find something around me to wedge under the lower control arm and do as you said DIG! But each scenario is deferent same as every car so its hard to answer your question correctly.
Edit: just remembered that i had to try and inflate a flat tyre to raise a car chocked the suspension control arm to keep the ground clearance then let the air out of the spare and punctured tyre and re inflated the spare when it was on but like i said every scenario is defferent yeh!!
My bottle jack lifts my 33's way off the ground - haven't measured but should be sufficient for 35's.
Here is a solution that might work for one of you
Attachment 25217
I have notched out the rear side for the standard Nissan Bottle Jack to fit on the base for jacking on sand
An 8" x 2" red gum sleeper is cheap. Buy one and cut 250mm sections off it. Perfect jacking plates with a big footprint and will not compress.
Can stack 2 and then the jack if you had too ;)
Coincidentally I've been playing with some jacks today. Patrol is now up on axle stands (for the first time) with the rear wheels removed. Have been cleaning up the chassis (well at least the visible parts) with an angle grider/wire brush in preparation for re-painting with KBS Rustseal.
I have a variety of jacks I could have used.
An exhaust jack, as yet unused. Didn't use it because the floor surface has some large gravel on it, wasn't sure if it would cause a puncture.
I have an old high lift jack, used it recently to remove wheels off my bus, even with a timber plate (19m ply) under it it was sinking into the dry dirt of the shed floor. Also a bit unstable side to side. Scared me a bit.
Tried to lift the rear of the Patrol with a small trolley jack on a metal plate, under the rear diff centre. It felt like it was really struggling with a lot of pressure needed on the handle. I wasn't game to get underneath to put the axle stands in place.
Have not tried the factory jack, but wouldn't use any jack on a brick. Have done this in the past & seen the brick disintegrate under pressure. I do use bricks for chocking wheels.
In the end I used one of the two 10t bottle jacks I carry in the bus. Wouldn't fit under the diff, so I lifted one side at a time with the jack underneath the rear axle. Axle stands placed on metal plates.
Will try the factory jack once wheels are back on. When travelling I will carry the exhaust jack, & a bottle jack plus a couple of pieces of timber. Removed wheels or locally sourced logs will have to suffice as a safety measure underneath the vehicle as I wont be carrying axle stands.
Cuppa
all jacks are dangerous, I use timber blocks, a 6x2 x 300mm base plate under the jack, I also have 2 of 6x2 x 300mm timbers that are splayed (wedges), one or both are used on uneven ground to get the jack level regardless of the angle the vehicle is at, this will get you out of trouble 99% of the time, when on a severe angle I use my winch to hook to a tree to steady the vehicle in one place then jack it up for an emergency tyre replacement, that one is does ASAP, never get under it ever, safety is paramount
My standard bottle will lift my axles enough to remove 35's when you place it in the right spot. When you say all the way up and its still not enough are both stages all the way out?
I would absolutely never use a high lift jack for changing tyres.
Hi lifts are recovery jacks and because they invariably lift off the body/bar work of a truck any vehicle that has a heap of lift and/or flex is exceedingly dangerous as every inch you jack it makes it that more unstable.
Even on any surface other than a rock hard, dead flat 'billiard table' you are asking for trouble.
I have had a bead pop off a rim out in the bush in a huge rut 1/2 way up a hill now known as "Evils folly" for obvious reasons and all that was required was stabilise the vehicle (it was at about a 30 degree angle) take the weight of the front wheel as much as was safe using the bottle jack and dig out under the tyre. Took a bit of shovel work and about 20 minutes to fix the truck and 2 weeks for the scars to heal from where the missus beat the shyte out of me. I am still deaf in the left ear.
Yes i sometimes carry a hi lift depending where I am going but use a wheel mate if I need to pack under a tyre hoewever my exhaust jack is first choice weapon and I won't tour anywhere without it. They are THE ducks guts on any surface especially sand and a carpet square means they work on rocks extremely well as they mould to the uneven surface
