yer that definately didnt sound right, I was going to suggest a decent LSD oil change but that has nothing to do with the noise I hear here
Yes your right mate. I took it back in and they put a light/camera into the diff and the sun gears and everything were all ok so they changed the oil to another type and also put in a bottle of LSD oil addative of some sort and now it all good. I havent had the chance to test it out under harsh conditions yet but I re-done what was done in the video and it seems all good. It turns a tight circle much better to, the wheel skipps a tiny bit but that may be just a good lsd working.
Well bugga me.. it sounded a lot worse than that.. good to hear its sorted though. Hopefully...
Owner of
Westy's Accessories
Have trouble getting my head around the fix, oils aint oils Sol !!!
Glad to hear all is well and you are happy now.
Wow you would expect the worst wouldn't you from that noise??
Funny how bad things turn out not to be and the little things bight you in the bum and turn into big things..
well you could blow me over with that one, seemingly oils arent oils at all as said by MACCA, certainly learnt something here, maybe it was a case of sitting around for a long time & the diff oil went to sh#t or maybe just the wrong diff oil, anyway, glad it was an easy fix for you, I like to hear about easy fix's, cya on the tracks
