Quote:
I still have to send Hi-Tech Diesel an email so they can explain to me exactly which vacuum hose it was, cause its got me stuffed.
Theres ones they installed while doing the Dawes valve, and all others are well out of the way.
I dropped the psi from about 17 to 16ish and also zip-tied the butterfly valve open before it hits the manifold, which I have recently been told plays a part in restricting air flow and over-boost.
Please correct me if I have been told a furphy on this one.
I have never heard of that but there is a first time for everthing... In a manual the butterfly doesn't really do anything, as once you accelerate it opens and when your idle it closes. I do believe a few manual owners here have removed the butterfly and it made sweet f.a difference anyhow. But the butterfly is needed for auto owners, I believe again, because something to do when the car is idle its needed to help control the revs so it wont stall. There is a thread on this somewhere I did read.
Quote:
Pushed it on the home run and it ran SWEEEEEEET!!!! Didn't climbe above 18-19psi at all
No lag, no drop in torque during up-shift (manual) maybe due to the butterfly being constantly open, and smooo-oooth driving.
Thanks to you all for your input.
Thats because you have dropped the boost, not holding the butterfly open. But i could be wrong. It may be only 1psi but thats all it took for mine to stop going into limp mode.
