There is only one contact point on the bottom. But I will check.
It may have worn the solder away on the contacts, common if lots of off road encountered
I went back and checked the poles and noticed what I didn't see before so a - on the multimeter. :oops:
Well I'm no sparky (see above :) ) so I took the inside panel off to see if the connector was on wrong and found this.
Am I right that even though red goes to the middle pin and black to outside on the socket that the connector is arse about ?
If so which way is easier, rejoin the wires somewhere between the socket & connector or get an auto elec to fix the connector or redo the socket ?.
So the housing is positive and the centre pin is the negative, this is why the LED is not working.
I would just cut the wires between the socket and connector and rejoin them the correct way around.
It makes you wonder doesn't....how could they get something so basic wrong.
There lucky the lights are all plastic and above ground.
With incandescent bulbs it doesn't matter which way the pos. and neg. are they will still work, LEDs it's a different story.
I have the same problem only mine is wired correctly. Centre is +ve and and the side is -ve.
A normal globe works fine.
The LED i'm wanting to put in there is the same type and base as the indicator in the lights in the bumper bar. I have put it in there and it works fine so the LED is ok.
Any other suggestions as to why it wont work in the barn door?
