No dramas mate we'll wait till then..
I don't know why you would even bother to change that stupidly dull light.
It is almost impossible to see if it's on or not in the daylight.
The best way to check is to feel if the switch is in or cycle it.
The only time I can ever see it clearly is on a dull day or at night.
Don't waste your time and effort.
It's like a few little annoying Nissan foibles another is that they still only have one reversing light , must be that we are only allowed to back into things on the right side because the left is nicely illuminated.
:icon_bonk:
Men are bright as Rod. But my A/C one died recently as well. So I am following with interest as well.
For me it's a matter of if it ain't broke don't fix it. In this case it's broke and I want it fixed.
Check this out it should help you.
Aircon Bulb Replacement
And this one;
Bulb
Regards,
David.
Am following this one closely as well. I actually wanted to change up the colors if could.
I found similar globes at jaycar and replaced my ac, was a little fiddly but easy enough, way brighter too so i replaced reticulation globe aswell. will get a pic for you when i get a chance. might even be able to get the jaycar part number.
recirculation*****
I just did all mine with 2mm leds blue from ebay. Jaycar sell them as well. Only prog was pulling switch apart and squeezing a resistor in there as well
