Wish I had seen this thread before I sold my alloy bar & bought a steel one......
Stephen
I took your advice and have removed the password protection so you can all access the fitting instructions here http://www.nissangupatrol.com/fittin...ructions1.html
I have even put up the fitting instructions for the latest product which is a glove box light. http://www.nissangupatrol.com/fitting-instructions.html Quite a simple kit but one that takes a bit of time to manufacture which is where the cost comes into it. If you are handy with a soldering iron you could make this yourself. Just remember that you need a normally closed switch not normally open.
David
Hi Toolman,
Did you ever get a look at the Simpson 50th Anniversary Edition GU bullbar?
I was in contact with you a while ago and you weren't sure if the cradle would fit the bullbar. I checked on the forum if there was anyone in your area who could let you have a look.
http://www.nissanpatrol.com.au/forum...030#post258030
I've used a winch cradle on a previous car and high tensile bolts are not anothe to hold them in I highly suggest you weld it on aswell if you are gonna use one as my winch pulled the cradle with it and ripped up the rails my personal opinion don't use it as you have a very nice vehicle and I'd hate for it to happen to you mate
