I'm happy with it so far, though I haven't done any serious recoverys yet, will let you all know when I have serious go at it.
I've had and used the tigerz 11 winches, both 12000 and there comp spec lowmount 10000.....for some reason i realy like these winches for what they, $1000 0r less with rope and fairlead. I had the lowmount comp spec tigerz11 winch and did a winch hill that the comp bloke did with there highmount, chalk and cheese between them both but from that day I was convinced on them.....The winch I do want will cost more than my truck....
I have seen the ironman winch in use and pulled out a really bogged gu (all qg's got through :) ) double line pull and it worked well
Good read, I'll be in the market soon with Bluey so good to hear some feedback!
There was yet another winch Comparo in a 4x4mag that has the word action in it.... ;) If someone still has that issue it gives a run down on the most popular winches...If I recall the ones mentioned so far were also rated well, another dark horse I think was the Mako winches...
Mako winches http://www.4wdshop.com.au/recovery/makowinch.htm
And superwinshes....
The biggest thing is you buy a winch for insurance off the track..... so look at what you want to use it for, are you going to look for trouble to winch out,or to have a winch just in case..
A mate has one and is always having dramas with it, especially after driving through lots of water. It must be one of the older versions that weren't sealed.
I love my tigerz, was $845 for 12000lb with plasma rope, so much better to work with than steel
http://youtu.be/GDJ3QjvRZT0
