Ill be dealing with him in future.
Thanks for that.
The top half of the split bush comes already on the new gear stick complete with rubber boot.
EX Japan $400.00.
Then after i pulled it all apart and did a measure up i find a circlip that just sits on top of the top half bush does nothing but sit there as a spacer.
Its 2mm thick and the gap is 4mm.
So im off to make a spacer up now for it 4mm thick this will hold the top half bush down onto the bottom half which sits on a spring. right now all assembled it has 2mm play in it. Up and down.
This is only a quick fix as im convinced the selectors are all worn out, except reverse.
This is what happens when you rest your hand on the gear stick. Im told.
All forward gear selectors rub out and create slop.
Im learning the hard way about the patrol.
Ball park figure for a gear box heavy duty clutch and titan exhaust system plus what he has already done 6K.
