Do you know where to get these adaptors from tim?
Would have to be what, 10 ltrs plus, thats an extra 10 kg a corner, maybe ok for the slow stuff, do you really think you'd get much of an advantage out of it. I'm thinking of the drive home and effect on braking. you can get lead powder to balance knarly mud pattern tyres.
The car its going to happen to is going to retire to a trailer queen soon so that side of it isnt a bother. I havent heard of anyone who has tried and im just gonna give it a go for my own experience sometimes it is the only way to learn lol
Ok Sounds good now, pushing the envelope so to speak, I was thinking of filling tyres with Helium but only for touring duties, worked out to be $60 a tyre I think, cheaper to rent a bottle. Look forward to your results
What about tractor supply shop???????????
we run water in our comp truck, 40" tires filled to the top of the rim! Just make sure you have decent chromo cv's. We have also run steel shot - about 80-120lbs per tire. steel shot is better for comps as if you do have a puncture you don't get a DNF for fluid loss. Its great for traction and climbing as the tire is now like a deadblow hammer and doesn't bounce off like a standard tire. If you urn steel shot then you need to add graphite powder to get the shot to 'run'.
HTH
Greg
I did some driving spreading fert at one point and they changed to putting water in the tyres, worked well but made life harder on the brakes and did break drive line stuff due to the extra weight
