Has anyone used a fuel filter as a catch can? Does it serve the purpose? FUel filters are much much cheaper than catch can. Is the filters used in air compressors the one referred to as catch cans?
Thank you.
Thank you.
Sort of, but most here use the Provent 200, these are add ons to help prevent the MAF from getting dirty.
Catch cans are affordable ,cant see why you'd need to use fuel filter type
Attachment 22151just run the hose down and out through the wheelarch and put a tap on it to drain
Hi i ran my hose in the same position but a bit further
along the chassis and then tapped it
I fab'd my own, using a generic turbo catch can from supacheap. Search me on the WApatrolforum if your interested in how I done it.
I know old thread but anybody know where you can get the 25 to 12.5 reducers please
I got the flashlube pro one. A comparison I was reading at the time had the flashlube catching more oil than the provent (at slightly more pressure drop), so that's what I went with.
All fittings and what not can be had from ebay.
