where i mounted my first battery isolator was next to the aux battery but the ctek is slightly larger unit and i wasnt to keen on haveing it that close to the turbo so i moved it next to the starter batt you can see the battery box i mentioned earlier that i fitted around the aux batt.
That is a busy bunch of wiring you have there. How do you manage it all?
7th July 2012, 08:52 AM
MudDonk
if u have a camper/caravan with a battery in it u will need a 1240 bcdc to run the system effectively, this unit is also solar compatable
