Have emailed them
Have emailed them
Hi I have just fitted a safari turbo. Best thing i ever did. cost $2900 installed and dyno tuned. Throw the ht 18 away.
I had the turbo on my skyline hi-flowed years ago. Changed from ceramic to ball bearing and machined the hell out of it. Yes alot better than stock. Probably would go a whole new turbo if I was to do it again.
A mate just did the swap with i think the GT2860 supplied and fitted by JPC in Melbourne.
He drove out with 135rwkw and is very pleased with the upgrade. He would want to be though as he got no change from $4500. to add insult to injury, when he went back to get it they said that it was getting really hot EGT readings and they'd need to Dyno it????? WTF? You mean for $4500 and a Turbo replacement Drive in Drive out service they did not tune it? $440 for the Dyno tune! Ouch!
Yes its JPC but Really!!! Thats a bit Rude.
Thats is rude but those turbos are known for the high egt's
Another vote for Matt at United fuel I have one of his TD05s The 18G and I can tell you you will be very Impressed with the turbo and the service they give.
Hey Mr Fridge did u have it fitted or diy as a kit?
Diy as a kit
You really need to stay away from the so called high flowed turbos.
Either machining housings for a different CHRA or whatever.
The standard compressor housing is not large enough to cope with increased compressor flow. The turbine housing is not so bad, and croping of the turbine wheel can help but at the expense of response.
United do sell a good setup, but the Garretts are cheap.
With the dollars the way it is you can buy all you need to swap to a Garrett for less than $2k.
Not sure of the price of the United setups but they are a little dearer.
I have no preferance either way it just comes down to dollars which way you go.
Either will take about a day to fit if you are handy with some spanners.
A simple turbo change such as this, setup to run the same or even slightly higher boost would also be perfectly safe to drive without playing with other things.
Simply bolting either of the turbo's mentioned on will not create higher EGT's unless something is drastically wrong.
As for the comment that the Garretts are know for high EGT's, why do you say this?
They may not be ideal but.
I use the same GT28 turbine with a .64a/r T2 housing at a drive pressure of 1.3:1 on 30psi and have no EGT's issues.
If I'm lucky I might see 11-1200degF pre turbo.
I have held it at 3900rpm in 5th with a 285 tyre for upto 2km with egt's steady at 1120degF pre turbo.
Admittedly this is not a standard setup but it shows that the high EGT thing is a little bit of BS.
Marty
Cheers Marty
I do like how informative you are and are very knowlegable.
I will try and clarify it a little. Yes the state of tune could be the reason they are having high egt's not necessarily the turbo itself. My comment earlier I should have worded it differently being on nightshift sometimes renders my brain a little slow. I have seen comparisons on turbos from matt at UFI and the garret had the highest differential temperature between pre and post turbo egt's but as you have stated are still a good turbo.
The UFI setups I have just actually priced one up myself and the kit is $2700 plus freight, that was for a TD05 18G. The kit included turbo, manifold, all piping and lines and 3" dump pipe, this is however a kit to replace a factory turbo so a full kit for a NA motor may be slightly dearer.
