X4 Oil and water is the way to go.
Oil trying to do both jobs is taxing the oils properties.
remember to give turbo sufficient time to cool before shutting engine off.
if you don't have a turbo timer Jaycar do a kit that also has temp sensor and adjustable timer.
Built 2 of these so far not hard just need steady hands.
cheers
i got a garrett, hits full boost at 2800rpm my brother has the ht and doesnt come close to mine
Hey there i had a factory turbo gu with a ht18 i tryd getting power out of it but it was a fail there to small for the motor and hav issues with massive flat spots when tryin to get more power out of them and are common for failure when pusht hard as for the water cooling just block it off on your engine and it will b fine.
