You will probably find OD that the factory wiring harness is in place in the guard and all you have to do is pop out the blank lens and you will nearly be a plug and play. The only problem light will be the reverse light as it only works on the Passenger side (go figure!) so you will have to run a single wire over to add the right side to the circuit.
Pretty basic mate. I didi mine on the side of the Murray River while camping ;) nice way to spend an afternoon ;)
