thanks johno but whats the diffrence between the wheels why 18g
also where do you find the coolant bung at the back of the motor
Its on the block on the exhaust side. I can sneak a pic of mine in the morning and throw it up if you like.
that will be great cheers mate nearly got everything in my head so time to so start some bits n pieces ! just 1 left whats the diffrence between 16g and 18g ?
The size of the housing and wheel basically.
16g the boost will come on quicker should be fine.
as said, 16g is just a smaller wheel and housing, its the type most kits come with and met common used on a td. i went 18g due to other factors involved in my specific case. also remember when fitting a turbo you will need to put more oil in then normal :P rule of thumb is about another litre.
Here bloke mines just an NA block hope this helps.
Champion cheers bud
