johno90
Hey, Just a bit of an update!
So up here in lovely Moranbah its Hot ASF! :) Perfect to test everything out.
Current setup is same as before except I now have an auto instead of a manual.
Test setup:
41 Degree day
2t Load on the trailer
33" tyres with 4.1 diffs
re4 Auto
36psi boost 18g turbo
Run along the highway and up the range.
Results:
Highway:
Coolant temp:90
Amb temp:48
Intake temp: 22
Water temp- measured at w2a rad: 10
Up the Range:
Coolant temp: 97
Amb temp:49
Intake temp: 24
Water temp w2a: 11
Boost constant around 30psi
All up I am very happy with how it turned out :) If i did it again I would probs get a bigger plate exchanger which would give better results again. Tho any bigger would be pushing the pumping limits of the compressor which is ok just means would have to mount up a slightly large compressor.
In saying all of this to, in cab A/C is still icy cold, no draw backs from the system at all.
