Thanks all for your replies. I still haven't managed to get it out. I will be removing the whole tow bar because i'm sick of smashing my shins on the tow ball. When the tongue is removed completely, can you see straight through the square hole? Or is there a wall in there or something that will stop me trying to bash it from behind?
You should see right through it no backing plate,
I'd be whacking the begeezus out of it like Kevin said left ,right up and down, even in.
Did you remove the locking bolt?
Can't see any locking bolts, but just incase, where will I find it?
Usually a 3/8th bolt to hold the insert tight and stop it from rattling
1 Attachment(s)
I'll go grab one, that's the lock bolt just in front of the pin and clip
Usually on the underside of it sometimes right on the corner of the box section.
Cheers guys! Unfortunately, no bolt on mine. :(
I got mine out with a tree trunk protector around a bloody big tree and a few good tugs, easiest way and I tried the lot
