looks good mate
looks good mate
great build so far mate. lookin forward to seeing this thing on the dirt. ( probably not as much as you looking forward to it though :P )
ozz
great work mate
Cheers guy's
NOt much more done except the rear wall to the truck which a big thing, as all i need to do is a bit of grinding as i have changed my mind again
More gear ordered
Tigerz11 awning with the silly prices at the moment
Rhino platform racks with a cool little mod with one http://www.rhinorack.com.au/AccSubCa...-Racks_74.aspx
Bit of detailing,
http://i223.photobucket.com/albums/d...y/bf7d2353.jpg
Fired up the engine for a good hour tonight, and gave it a little service as it been sitting still for nearly 2 years. Forgot how nice it sounds.
New battery,new hight torque starter motor,new ignition Module has been done over the past year. So I hope I can get from A to B,C,D,E,F and G I venture further. Always seem to break down in bad areas, but always been lucky to get it started.
Bit of wiring up tonight.
Something different
http://i223.photobucket.com/albums/d...y/8727f78b.jpg
http://i223.photobucket.com/albums/d...y/b452bd8c.jpg
http://i223.photobucket.com/albums/d...y/18b1588b.jpg
Haha like it...is that brake/ tail switched?
Or a switched fog light?
Nothing wrong with thinking outside the box.
Slip the light off, pass it and wiring through the rim and easy access to the spare wheel as required.(if ever)
Its both mate tail and brake.
The wiring will be all concealed and hidden away. This was the test run getting the loom right.
All wired up for the rear light set up.. Hopefully this will keep the DOT happy with more than enough brake/tail and indicator lights.
passenger side is not in as I cant find the bloody screws, Also the rear flood light in hooked up to the reverse power. So when its in revers it will light up the bush.
http://i223.photobucket.com/albums/d...y/0e3ea36a.jpg
http://i223.photobucket.com/albums/d...y/d2399762.jpg
Bit greedy,but have come up with a easy mounting bracket if you own a iPad . Will post build on it when I start.
http://i223.photobucket.com/albums/d...y/81c86909.jpg
Should stop buying toys and finish the freakin truck.
