Just scroll down to the twin compressor
http://www.arb.com.au/products/arb-compressors/
I have a single compressor, CKM12, but I have the tank and assembly from the twin portable one, will implement one day.
My UHF Icom 440 extension for the mike arrived, now i can mount it on the passenger side
1.8mtr long
I've heard that's illegal... do you know if that's true?
Can't see how it's any different to an air tank??
compressed air is a no no in case of collision. Better off buying a tested tank and bolting it to the chassis rail.
Had that idea years ago and was warned off it , ended up making the side steps into water tank instead even with
76 x 50 RHS by 1.8 mt long,,,not much water,
how are you going to test them , and what happens if it goes pear shaped
Compressed air test.
But it's my bus so I'll take that risk.
They won't be pressurized most the time anyway, only when needed.
Same as you don't run the air compressor all the time..
