Not a clue old mate - hopefully will find it whilst out though ...
Sure does!
1.06 A/r rear, that's referring to the rear exhaust housing size. The bigger the number the bigger the housing and the bigger the housing the bigger engine you'll need to produce enough exhaust gas to run the turbo efficiently.
0.5 inlet, that's the size of the compresser housing. Not a big important factor..
60mm trim, that's the size of the compresser wheel. Bigger wheel the more volume of air it can move.
Your issue with the massive flat spot at 3000rpm is that little turbo running out of puff. The exhaust side of the turbo isn't big enough to produce enough air volume to hold the set boost pressure. The 1.06 rear will sort that out!!
Its all about flow and efficiency :) that size should do a nice job.
You could run like the superior truck did 350hp at the treads with a 100hp shot of nitrous which was actuated by your foot getting to the the throttle stop on the floor :):)
That would only be running mild boost to wouldnt it say around 8psi?
