Perhaps a pushbike patch lol?
Cheers Nico Mate!
That’ll be the plan x 4 all needed once every tyre shop in Australia reopens next week now damn it [emoji23]
Unfortunately myself and many other locals have been issued council fine warning letters to get under 100mm paddocks before midnight tonight. Every other year I personally do our smaller freehold parcel between 26th <> 30th December once finished work for the year.
Maybe I should send them a letter demanding their 1.0m roadsides grass heights be considered throughout the entire region [emoji23]
All sorted now, completely forgot one of our relatives worked closely with some Legends to teach us all some Bush tricks [emoji123][emoji106]
https://en.m.wikipedia.org/wiki/Bush_Mechanics
8:18 Mark and I’ll be rolling again at 6:00am [emoji23]
https://youtu.be/X8WfjkgqK9A
Merry Christmas Legends [emoji319][emoji3590][emoji106][emoji106]
Now it is winter in Russia, and there is a lot of snow. I made the scraper myself.Attachment 82712
https://youtu.be/MD8QHSWI10Q
Hey Mark. I have a collection of larger Vulcanising Patches I carry when remote Touring. Size of thr palm of your hand. Great for patching tyres from the inside, especially those tyres that don't have a speed rating. If you get desperate yell out mate.
So I spoilt my 15yo son Zach for Christmas with a RMZ250. Lucky little shit. He had a YZF150 and was simply too big for it. This suits him much better.
http://www.nissanpatrol.com.au/forum...020/12/184.jpg
Today I pickup up this rippa. Show the missus last week and she said "That's a good idea!" So who was I to argue. "Buy Now" Click.
http://www.nissanpatrol.com.au/forum...020/12/185.jpg.
Picked these up after destroying my original set and the neighbours swapping out the rear coils.
https://www.ebay.com.au/itm/Heavy-Du...72.m2749.l2649
Added these to complete the new welder
https://www.ebay.com.au/itm/Tig-Torc...72.m2749.l2649
https://www.ebay.com.au/itm/BLUE-175...72.m2749.l2649
https://www.ebay.com.au/itm/500g-Bes...ar=64149425005
https://www.ebay.com.au/itm/500g-Sta...6415706&_trksi
Finally killed my Hitachi 18V drill, so replaced with this makita unit simply for battery commonality
https://www.totaltools.com.au/94164-...r-bare-dhp458z
You’re an ideas Man Mick Mate [emoji23][emoji106][emoji106]
Couldn’t help myself, had to borrow the girls 18v whipper snipper with the newly acquired add on hedge trimmer attachment, amazing contraption [emoji106]
http://www.nissanpatrol.com.au/forum...020/12/186.jpg
Smashed out the front hedge, all three sides approximately 30m long only using 25% of a 12.0AH battery [emoji106][emoji106]
http://www.nissanpatrol.com.au/forum...020/12/187.jpg
So much faster than scissors [emoji3574][emoji23]
You’re most welcome to come and take it for a try before you buy Mr Mark Mate! They also had a third extension shaft for sale too along with pole saws and edge cutter grass contraptions as well. I’d say this hedge trimmer attachment would max out at about 8-10mm thick woody “trees” though as it took a bit of encouragement on the ends where I hacked it right back a bit too deep.
Brought home the boys work saw beast for a quick renovation project in their absence:
http://www.nissanpatrol.com.au/forum...2021/01/50.jpg
Why the fark is this beautiful spoilt tool giving me kickback I questioned instantly:
http://www.nissanpatrol.com.au/forum...2021/01/51.jpg
http://www.nissanpatrol.com.au/forum...2021/01/52.jpg
Gates completely farked, heads need to roll I tells ya’ll [emoji2959]
http://www.nissanpatrol.com.au/forum...2021/01/53.jpg
Mitre boxes and blunt handsaws 🪚 welcome back boys 2021 [emoji23][emoji106][emoji106]
Well that is shit mate, s that fence 1 piece or Two? Surely it is 2 and it can me realigned? if it is 1 then how did this happen? If you need to use this and cant adjsut t to realign it then ut another fence on the front of it and pack it our mate. Re-fence it in a single piece with packers then cut the fence with the blade and you will get the job done no worries.
As ‘The Count’ would say #3 Pieces Mate!
http://www.nissanpatrol.com.au/forum.../2021/01/1.gif
Looks like an older/weaker TD42 variant after 25psi has been shoved through it [emoji23]
http://www.nissanpatrol.com.au/forum...2021/01/54.jpg
That's a bugger mate, it is a fantastic saw. Hopefully not too late to fix her up.
Gotta agree... def don't want a great tool like that becoming an ... wait for it....waaaait for it... eye sore.
Bwaaahahaha... see what I did there? jeez I'm hilarious, you mob should pay to have me on here, I tell ya I'm funnier than watching a nudist try and baptise a cat
Thes coil spring compressors arrived today, replacements to the two i destroyed on the 300kg rear coils. They look well made and should be stiffer than the originals - again, probably won't use them again as i am totally over coil spring replacement right now.
Attachment 82760
It simply makes changing the springs easier if they are shorter to begin with, especially when working off the garage floor. I apply the spring clamp to the compressed spring when the weight is on it, nip it up, then remove the wheel, jack up the chassis and lower the axle, spring pops out with minimal effort, then reverse the operation. I have limited headroom also with a garage door that covers half the car body and i have perhaps 40mm clearance between roofrack and garage door. Its not about trying to compress the spring, just maintain a shortened length.
Jack the chassis up, remove the wheels, drop the axle on the deck mate. You should have plenty of room.
I get fitting them while the weight is on, if you just needed to remove for maintenance and refit then all good, but using them to compress the next spring is my concern. They work, but i don't think they are needed mate
Why were they invented then Legends?
Honestly learning here too!
Darren, there was no next spring, it was the same spring going straight back in. I don't have the head room to jack the vehicle any higher. i accept what you are saying, but it just does not relate to the circumstances I was working with. I made some basic errors when doing this task, as follows - The biggest issue I have with the spring compressor is the stored energy that is magnifying as the coil is compressed, and that energy is not really apparent as the coil compresses until you start to see the threaded bar bending. Its is a very dangerous bit of kit for sure, especially if used without regard to the danger, but it can serve a purpose.
ERROR 1 -For the record I did remove the coil compressor once the coil was out of the car simply to re-align the clamps to 180 deg.for a better more level compression across the coil. This is where I came unstuck as I obviously over tightened the coil, despite measuring it in its compressed state.
ERROR 2 - When I went to release the coil, I also should have ensured the full weight of the vehicle was on it, like when it was removed - as the coil compressor was taking more load than original as it was still under single compression from the coil compressor, not the vehicle.
Your points are valid, just not workable for me at that time. If i was doing it without the overhead limits i could have easily jacked the vehicle higher and dropped the axle down a bit further - it was sitting on a trolley jack fully down anyway.
@MB They are used a lot when changing shocks in road cars due to them being coilover shock absorbers. You need to compress the spring before undoing the top cap. Remove shock, fit new shock with compressed spring and reinstall top cap. Then release spring compressors. Nearly all road cars that are around use this system..
Understand Now, Cheers Mat! [emoji106][emoji106][emoji106][emoji106]
Cheers Phil,
Yeah your scenario is basically what I said in the second half of.my post. If yoy are removing springs for maintenance and then refit all good. But using them to remove then fit New springs can get scary. All good mate, you are a long way from being a goose mate, you are all over it.
FWIW: Milwaukee replacement 3 piece fence/gate quote received and trying to make sense of it:
$298 which is near 25% of the entire 315mm weapons cost [emoji24]
They must’ve taken some lessons off Jefferson Ford in the day for XD plastic door internal lock $0.25....cent fulcrums [emoji23]
Still cheaper than a NEW glass eyeball for me or the poor blokes next in line, wish pricks would own their booboos, if not for any other reason than their fellow workmates [emoji106][emoji106]
.........TBC [emoji23]🪚
Unfortunately not mate, the bottom (main) fence is a one piece cast alloy unit and it’s currently as good as a Kmart Frypan that’s had a drunken Mule step in the middle [emoji51][emoji23]
@MB have you got a part number mate I reckon you can find it cheaper elsewhere
Quick Google, find me this. Might not be your saw and they obviously don't sell it but it's a start... They must be available somewherehttp://www.nissanpatrol.com.au/forum...2021/01/83.jpg
My mistake, it's available mate.
Here is what I have.
https://www.ereplacementparts.com/mi...695_10088.html
And see pic of it at checkout stage.
Fingers crossed this is your saw, else you may find it on this websitehttp://www.nissanpatrol.com.au/forum...2021/01/84.jpg
Thanks Nicco, appreciated Mate, I’ll pass this link onto Jay as he’s back there with the saw today[emoji106][emoji106]
On many occasions I just buy stupid shyt like this.. 😂😂😂 Attachment 82811
Bucket pickup yes! No where near as good as a mains powered decent unit, eg my hitachi, stings when u shoot your foot at close range, but being aldi you can return it if you dont like it, no questions asked, and has 5 year warranty. I think I will keep it.
