Did this show up??
Did this show up??
yep Got one myself for when I hook up my amp, very well priced on evilbay too
Bought myself an Adrad replacement welded intercooler for the troll. Time too update my leaky one
A spark plug. I might buy the rest of the lawn mower tomorrow.
The smaller 35 amp Anderson connectors are fantastic, I use these almost exclusively along with a rig runner power distribution block on the back of the car.
http://www.powerwerx.com/powerpole-p...nner-4005.html
This arrived today, it will house a 20 AH deep cycle battery and power
my led flood lights for around the camp or down by the river,
20 ah is heaps for a weekends lighting.
As Im down sizing Im also thinking of ways to increase
space used. nearly got it all sorted. Aim is to travel as light
as possible but still have all the comforts of before. Even made a smaller Tucker box lol
Now just need to finish the rear cargo shelf before I go away early DEC
I'll lay it all out on the floor and double check before I go
This arrived today, small battery box it will house a 20 AH deep cycle battery and power
Nice 3D's where did you get the small battery box from? I'm looking for one for my 20Ah also
Picked up myself a new multimeter from repco on special for 1/2 price
Attachment 51633
I'm unsure how I feel about this purchase but imo it's the best thing since sliced bread. But I'm unsure how I'll feel about bolting it onto the gq.
I bought a dual tank filler neck off a 100series cruiser.
Both ports under cap.
So yea. $50 and in bloody good condition.
I love my dual filler, but that's in a GU.
Yea I know you can fit 2 separate caps in the gq fuel cover but it's tight.
Much prefer the single cap.
Why do you prefer it?
Ended up buying a 55ltr water bladder, I will use gravity as having
a pump etc just means something else to break down and use 12v power.
and it all adds to extra weight I dont need.
I think bi-carb will clean the inside and rid it of any smell or taste
Brought this volt meter but with no backing plate, it will fit great in the centre dash on the LHS
under a rocker switch I have there, check shop in electronics
http://www.ebay.com.au/itm/Digital-V...item27e6ca388d
Edit its to monitor my Aux battery
Bought a cheap wet/dry shop vac to clean out the underground pipe from the house to the water tank. It worked a treat, after the drain caps were opened and the smelly water level dropped I got 5 x 15 litres of really nasty stuff out. Then went and cleaned all my gutters in a quarter of the time it used to take. I will have to spend some cash to re-plumb the down pipes above ground.
I'll make a fitting that easily reaches the gutter under the projecting edge of the tin, and that will make it even quicker. I might also tape the wheels up so the vac doesn't tend to roll off the roof
I got myself one of these blowers for blowing out my gutters. Works a treat weighs bugger all so it's easy to handle when I'm on the roof and has no cords or hoses to trip on. I already had the batteries so the blower only cost $59.
http://www.ryobi.com.au/Products/Pow...erVacs/CBL1802
Shop Vac super, stainless steel tub. $85 I paid way too much, but I needed it today, so I could get the system ready for the wet weather due this weekend. Also, the vac got rid of most of the algae and moss a blower wouldn't touch. I have seen them advertised for $47 at Godfreys. But there isn't an outlet anywhere near me.
Received my arb copy LEDs today, the quality is unreal, I think arb should buy them if they don't already.
Attachment 51662
Attachment 51663
[QUOTE=Stropp;555516]Received my arb copy LEDs today, the quality is unreal, I think arb should buy them if they don't already.
waiting on your freeway 110kph test, Id like to know if you have enough reaction time
But you would would High beam anyway
The LED sign lends towards it being ARB IMO
Reaction time for what?
http://www.ebay.com.au/itm/Water-Tan...f5928b7&_uhb=1
Brought something similar to this to clean out my water bladder when it arrives.
Reaction time really, you dont want to be doing 110 k with low beam you would have no reaction time if anything happened.
You have a light bar yes they give great light sideways but not much forward, I'll wait and see what Stropp thinks
I went and bought the Aldi black box recorder today.
http://www.supra-electronics.com/pro.../Maginon-CBB3/
Physical quality is pretty good and so far recording quality in HD is pretty awesome for the price. Lets see how long it lasts though.
I plan to use it to record off-roading, from a windscreen perspective, rather than a black box recorder.
