You getting the62 number plate on it 😜
Brace yourself!!! #The62 is gunna Rock!!! Dripping in Goodness!!
http://www.nissanpatrol.com.au/forum.../2022/01/4.jpg
OK shit got Real Again!!!! These things! Seriously. Everything is PULL LIKE FARK and pop the clips. Everything is clipped in.
I have a Factory Nissan trailer plug loom to fit and while I'm there will fit the KO Gear rear locker override switch making the rear factory Locker closer to an E Locker in function.
I will do a separate thread for the plug and play loom install too.
http://www.nissanpatrol.com.au/forum...2022/01/15.jpg
http://www.nissanpatrol.com.au/forum...2022/01/16.jpg
http://www.nissanpatrol.com.au/forum...2022/01/17.jpg
http://www.nissanpatrol.com.au/forum...2022/01/18.jpg
http://www.nissanpatrol.com.au/forum...2022/01/19.jpg
http://www.nissanpatrol.com.au/forum...2022/01/20.jpg
In this photo you xan see that factory Sub Woofer. Much smaller than I expected. This is the location that guys are fitting a double ARB compressor in the Ti option.
http://www.nissanpatrol.com.au/forum...2022/01/21.jpg
http://www.nissanpatrol.com.au/forum...2022/01/22.jpg
http://www.nissanpatrol.com.au/forum...2022/01/23.jpg
The factory loom had a plug waiting for thr loom to plug into which is very bloody handy.
The Loom though was EXACTLY the right length.... another 150mm would have been nice damn it! It wasn't Free!
http://www.nissanpatrol.com.au/forum...2022/01/24.jpg
It has a new grommet incorporated so pull and and put through. Winner.
http://www.nissanpatrol.com.au/forum...2022/01/25.jpg
http://www.nissanpatrol.com.au/forum...2022/01/26.jpg
So here is the internal Trim panel I had to pull out!
http://www.nissanpatrol.com.au/forum...2022/01/27.jpg
The factory Sound deadening is pretty cool. Like wrapping it in a quilt!
http://www.nissanpatrol.com.au/forum...2022/01/28.jpg
http://www.nissanpatrol.com.au/forum...2022/01/29.jpg
So while it's off the KO Kit goes in too.
http://www.nissanpatrol.com.au/forum...2022/01/30.jpg
http://www.nissanpatrol.com.au/forum...2022/01/31.jpg
http://www.nissanpatrol.com.au/forum...2022/01/32.jpg
http://www.nissanpatrol.com.au/forum...2022/01/33.jpg
Selectable switch hidden behind the rear vent. It's a set and forget but if you had to turn it off then a screw driver through the vent to flick it off.
http://www.nissanpatrol.com.au/forum...2022/01/34.jpg
http://www.nissanpatrol.com.au/forum...2022/01/35.jpg
http://www.nissanpatrol.com.au/forum...2022/01/36.jpg
http://www.nissanpatrol.com.au/forum...2022/01/37.jpg
http://www.nissanpatrol.com.au/forum...2022/01/38.jpg
And this is how I packed up last night..
http://www.nissanpatrol.com.au/forum...2022/01/39.jpg
Here are a couple of shots of the clips used to hold the panels on. They are identical to the clips holding on the door trims on a GQ...
http://www.nissanpatrol.com.au/forum...2022/01/40.jpg
http://www.nissanpatrol.com.au/forum...2022/01/41.jpg
Then the instructions again. The pieces MUST be put back together IN ORDER. Take note. I fitted, removed, refitted, removed, item 4 3 times....lol.
Read the bloody instructions damn it!
http://www.nissanpatrol.com.au/forum...2022/01/42.jpg
http://www.nissanpatrol.com.au/forum...2022/01/43.jpg
Interesting! How does each of those selectable options behave?
And why not have the switch in easy reach of the driver, Darren?
So this override switch is linked into the factory loom. It changes the function of the switch in the centre console area to select the diff lock. The switch at the rear is purely to switch between the factory Loom and the override loom. For the most part I will never need to turn it off again. If ever I do I can.
The difflock switch now functions on the same basic principle as an E Locker. On/Off.
