Is $650 the regular price for that front bar your mate did?
How many points for spotties and aerials does it have or does he add as many as needed?
As many as you want put on no extra cost on that.
Well put a new Grill on to n cut a the right size hole out for himount n looks much better.
http://i270.photobucket.com/albums/j...94434689_o.jpg
Well Smurf now running a single Din GPS receiver running XP Pro Car PC with 7inch touch screen with full version of Oziexplorer for Bush n a Normal Car gps for road use.
Screen mounted on passenger side n receiver is under stereo on dash
http://i270.photobucket.com/albums/j...65911985_o.jpg
What info do you want to know about it?
Saves me writing a heaps.
The Screen is mounted with the factory mounting bracket it come with flat to the dash beside jesus bar witch holds it there in its place put will come loose.
The screen it self has a 10mm bolt hole in middle letting you to bolt off it so i made little bracket up screwed it to dash on the metal n bolted to screen holding it nice n tight.
http://i270.photobucket.com/albums/j...14115526-1.jpg
And here's pic of the gps receiver as asked.
http://i270.photobucket.com/albums/j...1-14115429.jpg
Well swapped out my normal GQ diff today for a Braced up one was fully braced when i got it all i did was weld 6mm thick washes around radius arm bolt holes to stop the holes stretching out n giving me death wobbles.
http://i270.photobucket.com/albums/j...25068687_o.jpg
