Looking good Scotty, definitely a tuff ride, good luck sorting out the last of the gremlins.
I have never looked at the patrol wiring but i remember a commodore a few years ago that had a transmission fuse blowing and it ended up being the trailer plug wiring in the boot shorting on the reverse light circuit.
If it is blowing a transmision fuse i'd say it would cause the tc to not work at all.
I remember wiring up a torque converter lockup switch on a gq about 8 years ago from memory it put power to the lock up solenoid an easy test would be to do that yourself and work back from there.
I have also heard of the switch in the gear selector being at fault so worth checking that as well.
The trans computer being where it is does make it prone to water damage and i would also check it for dry solder joints and the plugs for corrosion they are a common cause of intermittent issues.
Their is an electrical contact cleaner lubricant available from most electronic stores like jaycar dick smith etc.
I am not 100 % sure of this but i think from memory the trans computer on the carb models has a few factors used to calculate the tc lockup as well tps vs speed etc so anyone else having trouble it might be worth checking the tps with a multimeter to make sure it is working properly as well.
