Yes this is a problem for sure. But let's consider in that recovery the soft shackle will be used at the anchor point, ie. The tree truck protector if the hook won't work or if the Double line pull is needed.
We don't need to over Engineer anything, and the steel gear still has a place for sure. The Soft shackle should be used wherever possible though bearing in mind sharp edges.
I recently also invested in a 50mm square hitch receiver specifically designed to take a soft shackle which I will run on the back of the62.
