Cheers mate!
Got a phone call from the local hardware store....nah not the green one....the one with dogs doing their shit....I mean advertising......just won the fsthers day competition for WA... it's taken a bit longer than usual as the first drawn winner is in jail so they did a redraw....and thank ya mother for the rabbits the next name drawn was mine...http://www.nissanpatrol.com.au/forum...2021/09/85.jpg
I drove the Patrol to work today. 25k there and back of suburban driving. Fark me! It’s actually a joy to drive it! It’s never gone so good. The different setup with the boost controller has obviously done the engine good. Way less soot and boost is coming on a lot earlier and holding it high in the revs too.
It’s a whole new beast to drive now.
That's because you are using a proper boost tee instead of a needle valve. A needle valve will always allow flow through unless it is completely closed. So effectively you were always slowly bleeding to your wastegate and having it open before it should have been. The turbosmart one is like a relief valve. You are adjust the spring tension to an opening point. Once this point is reached the valve opens and allows the wastegate to open and control boost. This has its limitations and is why electronic controllers are so good.
Thanks Mat, makes sense.
Another thing mate. Speaking with a customer of mine he suggesting to have the boost supply to the Tee on its own and NOT have it sharing supply with the injector pump. This way the compensator will get "actual" boost signal, not a shared signal which may be incorrect due the the controller bleeding off.
Sound right to you.
Glorious day up here .
Nice one Eric! Are you on an adjacent parallel-line tower or is that from a drone? Are you in the pic?
@mudski I hear there's an opening in the cherry picker if you're keen! :D
My wood stack is growing. I'm about 10% though the wood I collected from the storms. Should be right next winter [emoji3]http://www.nissanpatrol.com.au/forum...2021/09/99.jpg
