Are you allowed to put big stickers across the top of your windscreen?
Fixed loads of annoying little problems to get it ready for the QLD meet up....Not long to go now!!!!
Flares, plastic trim under arches, filters, leaks, organised, etc....It's finally coming together now!!!
I will buy you a windscreen sticker for free and post it to you for free.
There is only one condition I will do this.......you must post a picture of your truck, with the sticker on the windscreen, on this forum. Deal?
Please PM (Personal Message) me your address so I can send you the sticker.
It may take a few weeks to get there because I am moving, but you will get it!!!
Take care out there.
Ross
PM sent ;-)
Hey Pierre,
I know this sounds a bit cliched, but a shot sometime with the Eiffel Tower or some other notable French landmark like the new Millau Viaduct in the background would be great.
But if not, even just NissanPatrol.com advertised globally is a good thing.
Mark
Hi Mark,
I don't have pictures with viaduc de Millau or Tour Eiffel at the rear and a Patrol in front.
But you can see pictures of them here :
Viaduc de Millau
Viaduct Official website
Tour Eiffel
regards
Petit caillou.
Fitted 15mm coil spacers in front to get the beast sitting pretty and removed front radius arms to fit castor correction bushes in . Got a press at work and will fit 2 degree rubber correction bushes in during the week .
Come on Pierre,
We need a shot of YOUR Patrol(with the new sticker)with one of these landmarks in the shot.:thumbup:
Think of it as a road trip
Mark
Got a call from a damzell (?) in distress. Her and hubby broke down about 120ks from where I live, with gearbox trouble. No gears at all - vehicle in neutral, but stuck in 4wd.
The vehicle involved.....a Zook!
First thing I loaded into my truck was my camera, followed by the recovery gear. lol
Sorry Wayne, you're too far away for payback. lol
Installed my subwoofer today, swapped it out of the work van. Had some problems with it initially as I didn't have a good earth, fixed that up promptly and then I turned on the radio and it didn't work, didn't have time to trace the cable before it got too dark to work but found one end of a cut coaxial cable in the engine bay.... could be an old CB antenna cable from previous owner or I may have somehow cut the radio antenna......frustrating stuff.
Nothing like a good bass emanating from the rear.
Are we still talking about stereos
I towed a boat with it & went fishing..... 10 min old brown trout fillets eaten right out of the pan.... BEAUTIFUL.................lol
Installed new hd rear lower control arms. The front bolts were a b$&!h to get off!!!!
Attachment 19180
Attachment 19181
G/day Kris, whe're just doing the do mate this end mate (as you do...lol)
It was a great days fishing & just breathtaking views from where we went.
The great outdoors, I could be or live without it.
Hope all's well your end mate & feel free to pack up the family & come stay at our fire & fish till your arms fall off............lol
Fitted the roof rack that's been off for two years. Only temp tho
Attachment 19182
Tap, Tap.......Who's there?
Washed her, got my finger jammed in the gate :furious: then had an idiot at the front door :mad: after all that she still looks good:smile::smile:
Handed over $470 to get the alternator replaced. Still not sure what I did during the service to screw it up, but apparently was already on it's way out as the windings were shagged, and the earth point was not properly connected. Oh the joys of secondhand vehicles.
Good news is it now has fresh oil, trans fluid, fuel filter, oil filter, air filter, battery terminal, alternator, tyres rotated and NADS mostly done (fine tuning on the dawes valve to come).
Installed my TurboSmart incab manual boost controller.
Attachment 19185
And took a few shots of the new head,new fitting for inlet manifold, thermo housings and other bits and pieces
Attachment 19186
Attachment 19187
Attachment 19188
Attachment 19189
I sold it, well actually swapped, had the choice of a Toyota or a case of bourbon.................... Took the case of bourbon :)
Fitted my new Millweld Commercial winch bar!!!
Chased and discovered why my headlights weren't working.
The fuse box in the driver's side kick panel has two fuses for headlights. Two circuits, one power feed.
Cut the wires loose away from the green death and installed an inline fusible link to them.
First time, wrong way around one light stays on with a constant power feed and forgot to put heat shrink on one end
Second time resoldered heatshrink on both no worries mate and works a treat will put photo's up for those interested.
Went for drive and RHS light globe (sealed unit) seems to have air in it and smoked up and blew out. Damn cheap lights
Will be purchasing hella sealed or semi sealed globes for the beast now.
Pressed in my new offset bushes into the radius arms today at work . got them home and scrubbed and wire brushed the arms and painted them gloss black . start install tomorrow night - hopefully .
Ordered a set of ProComp EX9000 ex US delivered well under $300
Ordered my 2" springs
Lift here we come, alll under $600, just need swaybar disconnects
Picked up a cross country cooler for my zd30 800 bucks off a good bloke from this forum
While at work, I was learning to weld using a mig welder. For my first project, I decided to make a fishing rod holder for Theo. Got it all fitted and ready to roll for when I actually buy some rods haha
replaced broken rear tail light in bar, and finished buffing the scratches out of it.
ozz
Fitted front radius arms back in this evening . new rubber bushes . happy days .
Fitted a 3inch Redback exhaust, well, finished on Tuesday it was.
http://img210.imageshack.us/img210/2...31large.th.jpghttp://img33.imageshack.us/img33/733...34large.th.jpg
http://img684.imageshack.us/img684/5...43large.th.jpghttp://img38.imageshack.us/img38/817...46large.th.jpg
Finished off my accessory plate in the rear...
http://img13.imageshack.us/img13/323...0largec.th.jpg
fitted another ciggie socket in the blank in the console...
http://img88.imageshack.us/img88/813...41large.th.jpg
and fitted the recovery plates yesterday.
http://img221.imageshack.us/img221/7...40large.th.jpg
Now for the next project...
gave the truck a steam clean underneath and under the bonnet, just to see what it had under the muck!
Put a 100watt hid kit in my light force man they are awesome!!
Connected the blue/white wire that controls the auto-antenna that Autobahn couldn't be stuffed doing when they put the stereo in.:furious:
Packing up the 'boot' with stuff the removalist won't take.
changed the blinkers and parkers over to leds in bull bar.
