where do you buy the gas bottles from? I rent from BOC, do they sell them as well?
Around $65/qtr and I might not do any welding for 6 months, so yeah, it's money for nothing. How much are the E size bottles?
Here in QLD I paid $479 for each full bottle and $159 each refill so basically $320 outlay per bottle initially.
Seam. Brewed a shovel
http://www.nissanpatrol.com.au/forum...2020/11/13.jpg
Yesterday a parcel arrived from Ali Express. I bought a syringe for crosspieces. I've already done everything today.
http://www.nissanpatrol.com.au/forum...2020/11/18.jpg
Being a pressure vessel, yes they do. Whilst you buy and own 'the bottle' its at your discretion as to whether you refill it specifically and retain that bottle or simply do a swap out. You can buy brand spanking new bottles also instead of from a fleet. I will check the expiry on mine in due course and ensure it is swapped out before expiring just in case there is some push back. At the end of the day its a straight forward process to get the bottle retested and re-certified also, costs about $50 from memory.
Hey Phil, were do you get bottles recertified? I've got a bottle, the shape of which I've never seen anywhere, it is old, at least 30, maybe closer to 40 years.
I just rang the supplier of the my bottles, Speedigas in NSW. They distribute from NSW. They said the bottles have an expiry date, waiting for a return call on what that is, however because they only do a gas bottle exchange process, the bottle you buy has already been retested and certified each time its refilled by them. the manufacture date must trigger some internal company processes to then do further thickness testing after some period, say 10 yrs , at a guess. They did however clear up a discrepancy re the gas bottle ownership program in that I cannot get that bottle specifically refilled as they don't have a refill facility in VIC, all their bottles get refilled and tested in NSW, trucking back and forth across the country.
I asked about the process of exchange or retesting of any gas bottle, and they only would accept a Speedigas bottle on an exchange program. If its from one of the other 4 gas suppliers, elgas, boc etc, they would likely take the bottle as an exchange, and then carry the risk of it being servicable or not, or reject it outright and refuse to swap it. i think I would simply ring around and find the right person to clarify the test process. It wasn't that difficult, but the cost is the new valve head, visual internal inspection and then if they hydrotest it or not or ultrasonic thickness testing - each probably has their own process. i will revert when I have details on the perceived life of a bottle, but for unfired pressure vessels, its a combination of wall thickness and wall thickness degradation over time and thats about it - if the wall thickness falls within the guidelines and it holds pressure, good to go. I think you might have to take one on a rental program, but could be wrong. At a minimum I would spruce it up a bit before swapping it out!
Thanks for that info, appreciate the help.
And here you can only write about the tool that you bought or you can show the tool that you made yourself?
I made a sandblast out of an old freon cylinder.
http://www.nissanpatrol.com.au/forum...2020/11/28.jpg
finally after decades got one of these. wanted one before I could weld, then I could weld so just welded nuts onto stuff, but the time came ...
Attachment 82458
Attachment 82461Now get these! 😀
RivNuts/NutSerts rock you’ll love em [emoji106]
Just be a wee bit careful on the high quality 304HC stainless ones, the Kinchrome tool kit may break a handle if your hole size isn’t exactly to spec or slightly greater as they’re a lot tougher them stainless ripper serts Mick kindly suggested [emoji106][emoji106]
We cheat with playgrounds, pneumatic guns [emoji123][emoji23]
Ho lee chit mr Mark. I only broke the mandrel on mine Attachment 82462
(Special order for about 13 bucks from bunnings if you do strip one of these)
Crikey, that’s a bargain Mick [emoji106][emoji106]
TBH, our pneumatic work guns are so temperamental tuning in, thinking about going some Kinchrome’s too for on-site needs.
FWIW: Back in the olden days [emoji23] We used simply a bolt/nut/washer/grease/washer then our RivNuts at the end of line.
Hold the bolt hard with Vicegrippies and Shifter crank the top nut down compressing the RivNut to death, slow and sucks but works [emoji23][emoji106][emoji106]
A quick dodgey shed mock-up of a poor mans (emergency) RivNut tool [emoji106][emoji106]
http://www.nissanpatrol.com.au/forum...2020/11/69.jpg
Your an ideas man Mr. @MB. I like it.
Mini lathes from ebay
Anyone got one?
Milwaukee 18v Sabre Saw & 18” Demolition blade to the rescue again [emoji23]
Stumbled across some ‘Variety Bash’ Charity Legends between Woods Point & Jamieson this afternoon.
One in front of the VH General Lee accidentally stoved his front end in hindering all further Fundraising steering :-(
http://www.nissanpatrol.com.au/forum...2020/11/94.jpg
With the help of Milwaukee he should be able to easily fit 37x13.5” swamp tyres on his front right quarter now [emoji23][emoji106][emoji106]
Love em too Mark Mate!
Twas only a VH mock-up though, had it been an E49 I would have carjacked the bloke [emoji23]
FWIW:
Dodge Charger was the original Yanky General [emoji106]
Best Charger ever made was the Aussie E49 with A-87 (track pack) which its limited numbers snuck through for production line ‘qualification’ [emoji23]
Fastest Aussie ‘production line’ vehicle in its day beating the GT351 of 14.1 sec 1/4 mile with a 14.0 flat [emoji106][emoji106]
265 slant hemi six with triple 45mm weber pumpers and some ‘track pack’ cam work I believe did beat the 351 sorry to edumacate you Ford Fans [emoji23]
Saw those guys on the road on my way back today. . Somewhere . .cant rember at all where it was but [emoji848]
Used my rivet nut tool this past weekend. Why did I wait so long before I got one of these things.
Only thing to watch is not over stressing the threads when you pull them up. I installed some hinges on the 60l engel this weekend and used the riv nut set, like you have, and got a bit casual with the amount of pull up force and stripped one out. Took 5 mins to drill the bugger out then, lucky i could, if space was limited could have been another PeeBee cluster self generated. Best thing though.
haha, it's only a matter of time before I do that.
On what I was doing on the weekend, I measured and measured and took my time and still cut too much off something I had to shorten, now I've gotten lengthen it so I can secure it. Bloody amateurs.
FWIW:
If you find you’ve accidentally stripped one (Rivnut) fastest way to remove it we’ve found is to simply grind the head down slowly until it pops off like a washer.
Doesn’t seem to affect the surrounding paint but its only downfall is the internal part of the RivNut has a new forever home inside floating around if it’s a sealed cavity.
Rivnut nutsert users: if youre stripping them you are using aluminium ones, bad mandrels, or you have forearms like Popeye. Lay off the spinach or go Stainless :) :)
Scene #2 remake across the Howqua River was most Epic Rossco Mate!
http://www.nissanpatrol.com.au/forum.../2020/11/2.gif
Insisited they call Reidy’s after that action shot....way out of our GQ Grandpa Specs capability’s [emoji23]
http://www.nissanpatrol.com.au/forum...020/11/110.jpg
Can’t imagine how man poor Dodge Chargers were severely injured throughout the original 147 episodes [emoji24]
@MB was the Woods Point pub open?
Nah Chrisso Mate,was hanging for a Parma & Pint too :-(
http://www.nissanpatrol.com.au/forum...020/11/112.jpg
Kevington Pub still shut also but Jamieson open.
Bugger mate but thank you. We are up there for a day trip next weekend and was keen on a pub meal and sneaky couple of pots.
The travel buddy will have to do its thing to a couple of fourntwenties.
