Ha ha ha.
Mate....... You are the king of the comebacks, I'm looking forward to the entertainment.
Arrant lies! It is well known that Qlders are Gods gentlefolk. We would never suggest that Vics are ignorant enough to immolate a perfectly good beard.
It is however widely held in Gods country that VB is imbibed by our frozen cousins for it's inherent anti freeze properties!
Have you priced a replacement door from a wrecker? White will be easy to get. If it's say $100 for a door with no door card then I reckon I'd near on get a 4" grinder out and cut a big hole from the outside and open it. Then take the door off and replace it...... Probably would have done that about 2 months ago ;)
Sadly but MR may have the quickest solution,
"get the ST" she says "no Ill get the DX much better no electrics to go wrong"lol
Nearly there
So today is the day. I've got shit to do first up this morning so it'll be a lunch time onwards job. Here's some pics of the new door latch. The plan is to destroy the plastic cover for want of better words to enable access to the internal workings. It will require drills pliers screwdriver and some extreme expletives
I would really like to find the designer of this system and cut their nuts out with a wooden spoon. I've been looking at this lock for the last hour seeing if precision drilling of the latch pin would work but then the snapped drill becomes a reality as mentioned in an earlier post. Also to cheer every other GU owner up. During my research this bastard of a problem exists on ALL Patrol models not just the DX. You have been warned
http://www.nissanpatrol.com.au/forum...016/05/116.jpghttp://www.nissanpatrol.com.au/forum...016/05/117.jpghttp://www.nissanpatrol.com.au/forum...016/05/118.jpg
Can't wait to read how you fark this up!
The more i look at it the more im thinking of trying to drill out the pivot
Oh so that's the new lock mechanism, good luck with that ......... might have more success giving it to TD to use as a radiator cap
