How does your rear diff pinion angle actually look? If you could visualise the pinion shaft, it should be parallel to gearbox output shaft. When you lift the car they usually point upwards but as you mentioned you've got the longer lower arms. Personally I like the adjustable upper arms as this is an easy way to adjust the pinion angle as opposed to using set length arms.
