Bought a couple of SaaS gauges - boost and EGT
http://www.ebay.com.au/itm/321748023...%3AMEBIDX%3AIT
http://www.ebay.com.au/itm/321748016...%3AMEBIDX%3AIT
Just need to buy the pillar pod and then I can install them.
Attachment 60333
Camp cook up last weekend ?
Attachment 60334
More smokey pics before the dry wood was used
http://www.nissanpatrol.com.au/forum...2015/08/36.jpg
Tis my first and is an attempt to eliminate a drivetrain noise which I now suspect is due to the angles of my unis with a 3" litt causing a. Slack no slack issue on the chain in the transfer case at certain rpm. The set cost me $150 from bearing wholesalers on thomastown
Makes sense. I just bought my 1999 GU so I replaced them on mine as well as other bushings and bearings. Just was curious if it was a regular maintenance procedure or not.
