You'll know which place I'm talking about. Just head into town and keep an eye out!
Pretty disappointed with the mob that I dropped over $1500 in parts.
I did have an issue with the tie rod ends. The picture is of the note that was in the packaging. I put grease in as stated and black grease came out of the rubber boot. The grease that I was using was red. This tells me that the ends were already greased.
Their response.
They usually have some assembly grease in them and need a complete grease upon fitment.
So I went to Bursons and brought another one. http://www.nissanpatrol.com.au/forum.../2024/03/4.jpghttp://www.nissanpatrol.com.au/forum.../2024/03/5.jpg
Just received a fine for doing 46km/h in a 40 zone.
Not in a school zone by the way, just driving through the main street of Shepparton.
Bloody lucky they caught me before I killed the general public with my reckless behaviour.
I know the feeling. I had an immaculate record with over 20 years of drivers license (at the time) without a single occurrence. Then out of nothing, on a road I drive every day, I got a fine for doing 67 on a 60 zone. And the radar equipment had a 10% tolerance margin, so if it were 66, it would have been disconsidered due to being inside the error margin...
Yep I got one a few years back, about the same speed as well. I read the ticket and it actually said that the 10% variation was removed and the stated speed on the ticket is the actual speed minus 10%.
I couldn't complain as this street was somewhere I'd complained that they needed to change the speed from 60 down to 40 as it's busy and very tight. Little did I know, they actually had changed the speed limit.
Well it keeps on going.
The wife's outlander needs a new radiator, the worst part is that the hoses are going to be more than the radiator itself. No one has all three in stock, thought I'll try my luck with a Mitsubishi dealer. $270 and they will need to order them in as well. The radiator was only $130.
Then there's the low oil pressure on the troll. I can hear the engine coming good when the light goes out at around 1300rpm. Looks like it's going to need a fresh set of bearings and I still need to take in for the A/C and the trailing arm bushes to get my pre trip inspection..
It's f@#$ken hot [emoji3508][emoji3508][emoji3508] this weekend and I've been at it the last couple, next weekend is also out. Wanted to have everything sorted at least 4 weeks before the big trip and haven't even started on the extras to make the trip more comfortable..
For now f#$k it this is my long weekend.
Cheers all[emoji482]
https://www.nissanpatrol.com.au/foru...2024/03/10.jpg
