I found a positive spin on it PeeBee.
http://www.nissanpatrol.com.au/forum...2021/08/72.jpg
Thats the way Hodge'y, its sometimes the little things that work, enjoy.
Haha I feel alcohol consumption may go up in Sunny Vic this weekend lol. .
Finally getting the lithium all hooked up and rewiring everything in the back with central fuse box etc. . Going to run some wiring up to the roof with led strip lighting and light bar just cos really. . Will redo some wiring up front with fuse box pretty much just for lights then 24v for winch with two optimas under bonnet. .
The tight arsed local that will burn his rubbish, including plastic. Pharkin' stinks.
Bugger!! The drama with glass lenses and no protective covers. This is the third set of lenses too.
Attachment 84130
Fucking banks and useless brokers.
Here U Go mate, this is how a solar panel is properly installed. Fitted mine off tonight, will wire it in tomorrow... Probably. Bolted and wrapped gal tophats to frame and panel fixed down with 16mm wafer screws. Ain't going to where.
http://www.nissanpatrol.com.au/forum...021/08/126.jpg
http://www.nissanpatrol.com.au/forum...021/08/127.jpg
Bloody stuck here while the young bloke is moving into a new rental. He has no hot water and the laundry tap is pissing water everywhere when the washing machine is used. The real estate agents are being arseholes about it.
Most property managers are scum to renters. It's the only thing they're good at.
Years later with a cheap investment property, most property managers are scum to the landlord. It's the only thing they're good at.
In short, most property managers are scum.
Disagree? Call me out.
