PeeBee
If you have a single line pull with say a 4000kg load, the load on the rope is 4000kg, single point. If you run a double line pull with a 4000kg pull, the load on each rope is 2000kg, hence you have spread your load across 2 load points, each of 2000kg, which is a good thing from a chassis protection perspective.. This is why the winch works easier with a double line pull than a single line pull, however the line speed of the rope is halved or there abouts(depends on the speed to load rating of the winch.) This ls why i mentioned the point of taking care with the hook up, as if you have a 8000kg load you are going to be better off with a double line pull as the individual reaction loads are lower (4000kg/rope) than a single pull direct on the winch drum. What you would logically expect is for a winch bar rated at 12000lb/5400kg, you should be able to do a single line pull of 12000lb/5400kg that reacts thru the mounts and the chassis or winch mount, with certainty, there will not be any damage as the load is spread across the mounts in the bar and the chassis. The amps will be lower, your battery will like you more and the winch will stay cooler. So, if this was on my vehicle, and I knew the bar was rated for a 12000lb winch, I would probably default to double line pulls to ensure the bar capacity does not get exceeded, unless its a load you can accurately assess as below the 12000lb limit.. In theory, you can pull 16500lb x 2 on a double line pull at the drum, which is in excess of the single point loading for the 12000lb design point, so for safety you should be able to pull 24000lb on a double line pull and not exceed the bullbar manufacturers rating. Only caveat on this is how the bullbar manufacturer calculates the loading point limit - which we dont know. Also this is based on a straight line pull, not a pull on an obtuse angle. Nic, you can see there is a danger with a single line pull on 16500 V 12000lb capacity, and even still a potential if you get too confident on a double line to exceed the individual line loading. As a direct example, the son in laws vehicle is max rated for a winch at 8000lb and upon inspection, i can agree its a piss poor construction, but frustrating as I have 3 x 12000lb electric winches in my garage however dont have the confidence to put one of these on for fear he pulls the chassis out of alignment of even pulls the BB off.
I am jus highlighting some risk. You are smart enough and experienced enough to think it all through and exercise caution, unlike the 'send it brigade'.
