MudRunnerTD
Hi Kallen,
To be honest i Ummm'd and Arrrrr'd about this for a long time. I took a heap of measurements of my old bar and the tow bar and there was very little in it. The old bar hung down and the tow point stuck out almost the same distance.
When i made the rear bar originally it was about 12 years ago. I Over Engineered it heaps and was / am confident that it is a Strong bar and up to the task. Well tested too i tell you. Back then though i knew less than i do now about Snatching forces off the tow point. No discussions then really about Tow Balls (well a little).
So this option removes all doubt i may have and i know for sure there is No Risk. I have managed the Risk as much as i can.
Note also the Significant Damage to the bottom of the LRA Tank!!! The Tow Bar fully protects the tank now and this damage will be almost Impossible to occur again! Big Winner and probably the deciding factor.
Once bolted up with the hook in it looks like it sticks out heaps!! But with the new rear bar on too it will not look at bad. I will cut about 150mm off the end of it and that will actually mean it will be a better departure angle than before!!! add the 37s and its a win.
The new Hook will be permanently mounted the same way as it is in that receiver but straight through the Towbar with holes drilled from the top through to the bottom so t will be very snug.
