Far out mate, huge improvement!
nothing GGGRRRrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrr
Not today but at the weekend fitted the snorkel! But now I have that "ahhhhballs" feeling did I retighten all the clamps!!
Attachment 58764
Yesterday I had both tie rods and steering damper changed and wheels rotated and a wheel alignment done.
Got all of the wheels balanced.
The thrumming noise above 80kph
has gone. It is amazing how you
get used to a noise as it
progressively gets worse.
While I was at the tyre joint,
I got to compare the treads
on a set of maxxi bighorn
mud terrains and BFG
mud terrains.
Apart from a few minor
differences, the overall
tread depths and patterns
seem to be of similar design.
And the headache begins... gonna swap over intake manifold, new glow plugs and injectors.
Ugh! First hiccup. Different stamped letter of the new to old injectors.
picked uip the patrol after the service and investigating the grinding sound from the front end, seems that when i had the last wheel alignment they screwed the bump stop bolts back in so when i put the 35's back on the lugs on the muddies were running on the suspension arm, screwed them back out and the noise is gone, bit of a shiny spot on the arms but no damage to the tyres :)
Cut my losses and bought this dash cam
http://www.sportgps.com.au/blackvue-...-dash-cam.html
I installed it all by myself, too. lol
Bloody nothing ,looks like the rack will stay where it is till the weather gets warmer
GGRRrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
LATE BREAKING NEWS.......... my sons have seen how peed off
Im getting that they assure me it will be on tomorrow.
so let it be written, so let it be done , ha ha
Damn it I was just going to cut more off it too oh well lol
Washed it. Going out 4wding tomorrow though :confused: oh well, feels better when you start a trip when it's clean.
i welded in the last plate and painted the area, bled the brakes and test drove bedding in pads and slotted rotors.
I had the CRA bar put in so I put the cargo barrier and draws in. Attachment 58886
also check that the unit WILL take 64G card
I have a camera that wont take over 24G and and another that wont even take a HD card
Mine takes a 4gb card and more than enough fo a trip up to the Murray [2hrs]
says so in the specs
Model DR650GW-2CH Full HD Channel 2 Channels (Dual Camera) Color/ Size / Weight Front BLACK - (Length) 118.5mm x (Diameter) 36mm / 120g
Rear BLACK - (Length) 67.4mm x (Diameter) - 27.6mm / 30gStorage microSD Card (16GB/32GB/64GB) Supported. (32GB INCLUDED) Camera Front - SONY EXMOR CMOS Sensor (2.4M pixels)
Rear - CMOS Sensor (1M pixels)Viewable Angle Front - Diagonal: 129Deg / Horizontal: 103Deg / Vertical: 77Deg
Rear - Diagonal: 129Deg / Horizontal: 103Deg / Verical: 57DegResolution Frames/Sec Front - Full High Definition 1080P @ 30fps
Rear - High Definition 720P @ 30fpsVideo Format MP4 GPS and Wifi YES - Built In Accelerometer YES - Built In 3-axis G-sensor LED Indicators YES - Built In Battery Built In Capacitor Voltage 12/24 Volts DC Power Consumption Max 4.8W Operating Temperature -20 - 60 degrees C Software Support Blackvue Viewer for PC or MAC. Blackvue APP for Android and iPhone Video Out NO Whats In The Box Blackvue DR650GW unit (Front + Rear Cameras)
User Manual
Power Cable
32GB MicroSD Card with Blackvue Viewer Application
Adhesive Tapes for mounting
MicroSD Reader
Coaxial Cables
One guy has gone to look at a clumysdoor, one son is here and the other is heavens knows where
again GGRRrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrrrrrrr
Ran a new 16mm2 welders flex from the alternator to the cranking battery with a circuit breaker in line.
Now I won't blow the main 65A fuse when winching under load.
Finally [big sigh] finally had my roof rack fitted woo hoo
Drove it through a puddle then up a hill. Was a good day.
http://i1083.photobucket.com/albums/...psx2xbmdxg.jpg
http://i1083.photobucket.com/albums/...psblkwypj2.jpg
Spent a good five hours today under the bonnet. Manifold is off, new glow plugs in, injectors out and a few other things done. Just waiting on confirmation tomorrow about the different letter stamping on the new squirters to the old. From what i have found they are interchangeable, but i wanted to wait, just incase. Then its time to put it all back together.
I could have put the old glow plugs back in as they were still working, they were metal tipped too, and no missing tips. Thing is these have been in the motor since i have owned the car, around 100thou k's. And from what i know of its previous history, been in there for a previous 100thou. And no timer on them.
Weeks more like months, both my boys are 6' plus and 100 kg they did it on there own
commenting "its not heavy" ha ha ha but its on and thats the main thing,
I even have a flag bracket, if any one needs aflag bracket for this
style rack I have an easy bolt on design.
yes put some pads under plates can use inner tube or similar
dont use anything that holds moisture
