You should know it never happened without pics, thats rule one lol
Had the scrub bars put on a couple of weeks ago by XLR8 fabrications
Attachment 55957
Made this in between renovations today.
Attachment 55959
Finally got my fridge slide in
Those drop slides are fantastic. If I put drawers in I'd save my coin for one for sure
put a 2nd baintech guage in to monitor the main start battery.this is wired via ignition
the 1st gauge is on the other side of the radio head unit, looks neat to me as not alot of room
for 52mm gauges in a GU imo
Flexed it up on some tyres cause I can.
Just put the rear diff in the shorty. Has a slammed ricer look now! Also have a time lapse video which I will put in my build thread.
Cheers.
Finished the longe range sub tank install. Chucked 30ltrs in it and the sub tank light in constantly on and I cant operate the pump. Ugh!
I've just disconnected the battery to see if this helps but I have a feeling I need to bleed fuel into the pump maybe to get it started.
I also readjusted the rear sway bat links and changed the oil. ..
Had 2 sets of key replacement buttons delivered today. Just swap 1 set over, super sensitive now but cant complain for $10 a set
Buttons are 1 unit and key a 2nd unit that plugs into the 1st.
Hey Threedogs Haha yeah I know. I did take any this trip I will get some feom the next one over easter
Removed the awning and my light bar, Patrol looks naked now.
Now a few more bolts to remove the roof platform and rhino racks.
Ahhh too bothered ATM
Took it to the beach for the weekend :)
Attachment 56183Attachment 56184Attachment 56185
Kept it hidden in the garage.
Chained my camping trailer 2 the bull bar!
Cleaned the high country dust out of it from last weekend.
Just finished off the NOS on the gq ;)
It works a treat.
12 volt pump and tank in the rear and thought I would run a line to the radiator with a few brass sprinkler heads that saturate the radiator ran by the ball valve in cab...lol
I just tried to overheat the gq this arvo with the camper and air con on 4th gear all the way up the big hill.
Temp only got to halfway anyway but dropped right down as soon as the unit was turned on.
Got a mini gerni gun and hose in the rear with stainless quick release fittings!
Hanging to test it out properly on those hills up to the Murray at easter!
Show us your tank by the way?
Fitted my "new" spare on the back door, complete with factory wheel cover, shoved the high lift under the back seat, then went and got it a little dirty on some tracks, good fun, next will be a bath for it!
Suspension is seriously sagging on the drivers side. Just ordered new springs and shocks from ARB, the same price I was quoted elsewhere for a known brand.
