A small fridge in the car has made a big different for me.
Storage drawers and storage crates for the gear makes life so much easier too.
Heres an easy one,
and quick note to self steel WILL be Hot after cutting with grinder. ooh yeah.
This is a copy of Medieval tool, could be used today scaled back a bit.
Only made from scrap material lying around
More suited to a tripod if anyone uses one.
If anyone wants to make one I'll post some better pictures
Not too difficult at all
Hey ThreeDogs, that looks like an old dis-arming tool!
@ BF saw a rusty one on Ebay UK, was used on an open fire on a swing away arm from memory
Same here l want 1 as well
that's Macca's design he called them the Jailer's keys for obvious reason.
Easy enough to make, 12mm rod and some chain link
Never welded i thing in my life, thinks i may have to buy a cheapy and start playing
@ Mitch just look at things in a different way , just cause it says one thing doesn't mean you cant use it for something else
Bit far away but if you get stuck yell out
If any one has some REO bar or rod laying around to make the circle you will need 945mm of rod.
slowly crimp in a vice to form your circle. would even work square if its easier, I'll whip up a square one tomorrow
and see how it turns out. Square I'd go 250 x 250 mm, pack easier too
Thanks for the great info, for a newbie this is pure gold
