Of coarse it is.
Headline news is about a dam cricket ball some sandpaper and lynching.
They should be lynching the Victorian Labor Party in the same manner as they are with those cricketers for misusing $388k of taxpayers money.
Paul Murray and most of his mob are about the only 'Journo' I can handle these days.
Absolutely goes all in about the rape of the 2 and 4 year old kids, the theft of taxpayer money, the snivelling gutless pollies and best of all the POS maggots infesting the ABC.
Opened every program this week challenging the ABC and also people who tweeted about the Cricket to also tweet about the pedo's raping kids in the communities.
Mongrel NT pollies haven't even had the guts to resign and the Feds too shit scared to even comment let alone intervene... thank God Matt Cunningham is all over them like a rash.
How sow....??
My bad, too much happy dappy rum! Please feel free to dwell and enjoy, sorry :-(
More disappointment really........
Half way through my month off, I was booked into a course and adjusted my holiday destinations to accommodate this course, only to find it was canned due to lack of numbers. I've rebooked and hopefully it will happen when they say it will be.
Think my turbo is shot (08 GU CRD), a squeal noise like fan hitting metal cowling has come on suddenly.
Run max boost around 21psi, Good spool. Good EGTs (ecu remap). Can stop noise on fly by slowing spool (open needle from 0.6 to 2 turns).
Thought possible a leak on the boost side or turbo. After ruling out boost ducting and hoses, I removed the air inlet ducting at turbo flanged alloy elbow, and with the engine revs @ constant 1200 RPM with needle valve closed (no boost measured), picked up a constant metallic squeal noise coming from inside the inlet throat of the turbo (opened needle 1.6 turns noise stopped)?
Going out to remove elbow off turbo inlet see what's the go (wear). Not happy
Hey Bidja. Have a read of my first post, in my thread here from a few years ago. It was on my 2009 CRD.
I also could have sworn black and blue that it was a metallic sound... Mine sounded more like it had sand in the snail under boost.
Long story short mine ended up being a cracked EGR pipe, behind the motor near the turbo.
http://www.nissanpatrol.com.au/forum...ted-or-leaking
Thanks Hodge, for comment. My EGR plate fitted at exhaust manifold. Just got the alloy elbow off the turbo inlet side, so cramped up in there (top bolt / block side) what a stuff around.
I am fitter & machinist by trade (now so log ago) so have a reasonable good feel for clearances. I recon I have .010-.015" (thou) side slap in the comp wheel shaft assy, cannot detect any thrust (end play) clearance. Maybe with increased spool (higher comp whl speed) harmonics or frequency increase causes comp whl to run-out and clips bore face of turbo housing. No physical evidence of scrap but early days and maybe just polishing phase as components are of good finish for the moment. Asking around for replacement turbo not much knowledge on suitable types. ECU Remap last Nov, eng done 125,000ks moves well (owned since new)..
