Is it at a shop now, did they take the head off, if so there's half the job already done.
Sent from my XT1033
Sent from my XT1033
I dont know why a few shops said motor out, but you're right most are done in the Patrol
@ Jaycee no its not at a shop and nor is it pulled pulled apart.
I think a ZD30 would be a tad more complex than a surf engine
again I have no idea, but I cant see the comparison motors or 30 yrs apart lol
First up John, it's jay see and how did you come up with the conclusion that you have a "blown head gasket between the water channels and the compression chamber"
A turbo 4 cylinder is just that, they may have things in different places, but having working in a Surfs engine bay, give me a Patrol with a ZD30 any day.
Attachment 66662
Attachment 66663
Attachment 66666
Attachment 66664
Attachment 66665
Attachment 66667
Sold..........
That is just bad news that the head gasket is gone, TD. Over 6k to get a head done sounds really expensive though. So what are are your options atm?
Just wait till my powerball numbers come through, I suppose lol
Why do ppl always take things the wrong way.
The diagnosis was done by Frank from Mr Cylinder head
who works on ZD30s day in day out, I have no reason to disbelieve him.
Other advice and tit bits came from Mudski , Chaz , Andrew from OnTrack,, Kealba and
Paul from Outback 4WD in Bayswater.
What's done is done Ill now nurse it till my numbers drop, Don't really want to sell it
just because the head is gone. PM sent MN
So I just did a quick look for parts. $1836 for a new genuine head assy and $195 for an engine gasket kit. This is all genuine parts to dont forget. They are also prices any man and his dog can get as well. So I dont know where you or these other shops are getting 6-10k from.
complete motor swap over
@go2engines mate look them up
WHAT! No one posted an eBay link...LOL
http://www.ebay.com.au/itm/New-Assem...wAAOSwJb9WtBBt
I'd be first removing the head and checking everything else. Cracked pistons etc etc. Last thing you'd want is to put on a new head then later on it drops the pin in a cylinder or two.
FYI, when my pump failed on the ZD I was going to just put a new pump on. Then I go the green light for the conversion. My old motor was stripped down at the workshop and they found number 4 piston was cracked. Even though the inside of the motor was spotless due to my strict oil change regime and the motor still when really good... So If I have spent the 4k, or what ever it was, on a new pump, it was only a matter of time for that motor. And it would have been 4k just shot down the dunny.
Just saying.
Without going back through all these posts, a question.
Why did you put that copper stuff in the cooling system, did you have an issue with the head before?
I don't understand all the to-ing and fro-ing when there probably was a pre-existing problem that you knew about.
Just seems like a good starting point of the diagnosis that was ignored, or have I got the wrong end of the pineapple?
Nearly a month and 400 plus posts, must be doing your head in. Good luck with the power ball, I'm told you must buy tickets first... bugger.
Fishing?
Stay here mate, you get more bites and the bait is cheaper
512, 512 512 512
Bait!!!
LOL... You keep quoting porno's. I'll keep quoting documentaries :)
gotta keep this going..want to see what fife one too gets ya
Thought I'd pop this here just in case TD misses the Clear hoses thread
http://www.nissanpatrol.com.au/forum...016/05/183.jpg
Hey John, what's the latest with the motor? Any updates.
Whats the latest on the donk John?
In no position to do anything ATM, still drivable for how much longer I dont know
Wonder how much my single cab camper would be worth $$$ ???
