Cheers mate
I got my wiring harness back today. Trucks booked in for the exhaust at Scotts rods for the first week of July. Starting to get excited now
Done about 80% off the running the wiring today. I need to buy some adapters for the temp and oil pressure sensors, so I can run the Nissan sensors. One spot I'm not sure of is the reverse fuse that is ment to be in the fuse box beside the battery. (From the Killa Kustom Kable instructions) there is no fuse there for reverse as per the top of the box. Can some one help me out with that? I've also ordered a nice looking momentary switch that is required for the power/economy, this should just replace the factory option on the console. I have checked things so far and I have dash lights and fuel pressure, so that's pretty exciting to see!! LOL.
Troy
Thanks Thirsty for the tip, I might consider modding mine too
Radiator and Thermo Combo was ordered today from Aussie Desert Coolers. If I receive the radiator before the weekend, I could possibly be trying to fire it up on Sunday. So far I have turned it over and everything seems Ok. Fingers crossed, she will fire up with out a problem.
Troy
Does it come with a shroud to suit the thermo's????
She Runs!!!!!!!!!!!!!!!!!!!
http://youtu.be/tf5eIO3pIOk
Radiator doesn't fit!!!!!! The shroud hits on the inner guards. This calls for some light panel beating. I bring out the hammer this weekend and get it sorted. Next month is the big one, Booked in at Scotts Rods for the exhaust on the 11th and booked in at Radius Fabrication for a custom airbox and 4" Stainless steel snorkel on the 22nd.
Troy
